rootar
rootar's Avatar
06.28.2008, 09:58 AM
disconnect the reciver from everything and plug an rx pack into it and bind it completely seperate from everything else ( nothing plugged into it) this has helped me, to check and make sure you got it to bind plug it a servo thats also not attached to anyhting and see if does what it should. after its bound you should be able to get the MM to program, also i dunno if your running a switch or not but my spektrum take a second to "come on" at first, if you not running a switch on the mm try putting a switch back in, plug in your pack the bec should power up the reciver and servo make sure they are working then flip the switch and turn on your mm. you shouldnt have any problems
