06.29.2008, 01:33 AM
also i dont have the right size bit to bore out the hole so i couldnt tap and set screw it fits perfect over the hex on the input shaft but is kinda sloppy on the threads nor do i have the correct tap to tap the connector. ill look in to that tho i got plenty of alum stock so i can try a few setups. my buddys got a lathe and hes got more taps and drill sizes than he knows what to do with. i just havent talked to him in about 2 years.
still lookin for options on a motor.
