ah-see
06.29.2008, 11:51 AM
You makee a mistake on the spur gear , the stock e-revo spur gear is 68T, mod .8.
So with your 4s li-po, gear it with a 23T 32pitch pinion, and you'll be in the 39-40m/h
On my e-revo, on 6s, with badland tire (5.85" OD) i'll use a 22T pinion.
Yeah i do know that 68T is the stock spur, but i was using a 54T spur that traxxas makes for the jato. Since a spur is cheaper than a pinion, i thought i would suggest another spur(~$3) instead of another pinion(~$12).
