droopy
06.30.2008, 12:49 AM
Originally Posted by SATAYO View Post
Droopy,
Can you send me some pics of you shortened Revo shaft setup...?
I would great appreciate it...
-ST
I dont realy recomend a revo shafty setup due to the fact that the revo shaft diameter you have to grind the ears that your shocks mount to so you have to relocate your mount points to the ouside of the arms, You also have to use your stock ends from the e-savy and put them on to the revo shafts there is some slop there so I made small plasic shimms the next problem is the pins on the revo shfts are longes so I found you have to cut them then hammer it a little to flair the ends to keep them in place.
I have not broken a revo shaft but the stub axels or the input side are prone to snapping.I have even switched to tmaxx stubs wich only reqire a bearing switch (2.5 model)
I recomend to completely switch to the 2.5 tmaxx or e-maxx shafts but you will still need to use your stock end that hooks to the diffs since tmaxx are 6mm and e-savy are 5mm.
