Electric Dave
06.30.2008, 09:07 AM
I doubt the extra 500mah on a lower C battery will help you that much... I would look at the enerland 4s 6000's 25c if you need the extra capacity.
Spinning faster (with lower load ie) does not draw more amps - Analogy Is it easier to use stair master fast with no load that slow with higher setting.
That really does sum it up well...
Thanks,
