redshift
RC-Monster Square Tube
redshift's Avatar
06.30.2008, 05:56 PM
I have no exp with the MMM, had 2 on order but cancelled when all the trouble started brewing. I run 2S+2S so it's as simple as running the fan off one pack, if you're using 3S and up then it's not so easy. The Novak 25's do push pretty good air at 5 or 6V, if you're running an adjustable bec then set it at 6V. I was actually using my two 25's for pack cooling back when I was running Nimhs, at over 3 inches away, which is why I needed the boost. No more of that nonsense, lipos don't need it. So I'd say 5 or 6V is fine if it's right on top of the ESC... as for mounting, can't help ya there.
