blueb8llz
06.30.2008, 09:55 PM
ive always read to overlap the tape by one inch. i dont know why it tells us to, im thinking it helps from the tape from peeling off, but if its gonna peel off, then wouldnt the 1 inch overlap tape peel off too? i think your idea is better, i may stop with the overlapping. but i do not know what you mean by turning your tire inside out on the rim and then apply it. You can get it nice and centered and keep it tight too??? when i tried this, the tire is sooo big the rim is moving all over the place. did you mean have the foam inside the inside out tire?
