DRIFT_BUGGY
DRIFT_BUGGY's Avatar
07.01.2008, 02:09 AM
Originally Posted by Cartwheels View Post
I cut a piece of 1/8th inch aluminum with a hole saw that is the same diameter as the motor for the front. Drill a couple of holes in it for the mounting screws. Works well. Even allows some heat dissipation to the motor mount. I use the RCM cover on the back.
Yeah I did the same thing. I had to dremel a little off the rear RCM cover for the back to be able to work with the new Neu's with the screws on the endbell. If my track wasn't so dusty with little rocks/pebbles I probably wouldn't of really worried about it
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
