MetalMan
MetalMan's Avatar
10.02.2005, 11:10 AM
Originally posted by coolhandcountry
It only does 10 cells cab king. I was looking at maybe another charger. I need to get something with more battery capability. Thanks. Have you tried this metal man? What about it your raise or lower you mv peak detection? If I charge the batteries together then they will be run together.
I haven't tried, but I have read that you aren't supposed to do it. All I remember is that charging NiMh cells in parallel won't allow them to peak properly. If you are going to get a new charger that can charge more than 10 cells, then you could take a look at the Great Planes Triton. It takes a 12v input (from a power supply or 12v battery), and can charge up to 24 cells. So, if you went with 24 cells on the motor you want to get, you could charge them all at the same time.
