Thread: Mamba Max fan??
phatmonk
RC carbon junkie
phatmonk's Avatar
07.01.2008, 09:22 PM
Originally Posted by TruckBasher View Post
Where did you buy this fan? pics?
Also a question, I just manage to ARM my MM with 16.5V (5S a123) even with a custom Voltage cutoff :) anyway, do you think I can use the red wire from MM to power the fan (only) and still run 5S A123?
This Sunon fan actually use magnetic levitation to "float" the spinning fan blade in a magnetic field to dramatically reduce friction, wear, and heat; making these fans run cooler, quieter and last longer than conventional fans. Ideal for use in any mission critical application, in applications where minimal fan noise is desired.This is a direct description from the Buyextras.com.This fan puts out double CFM then the Novak 2.5cfm 4.9 cfm compared to the Novak.I run my fan off the receiver and run 4s 14.8 and a CC BEC.I run a neu 15151.5d/f.I run my Brushless 8T in 80 degrees outside temp for 30 minutes and no thermal issues.
