crappppppp
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
crappppppp - 07.03.2008, 06:32 AM
HOLY CRAPP BATMAN. Just looking at that thing is incredible. You could push quite a bit of weight with that monster. I shutter to think how hard it will be to control such power in that truck. With the right setup you should be able to achieve some pretty high speeds with that thing. If you do go for speed you are going to have to really think about your entire setup, like taping your tires and using beadlocks rims to keep them from flying apart. Your drivetrain should hoold up nicely. WOW that thing is amazing. Good luck with that Jordon.
