07.04.2008, 12:39 PM
Originally Posted by Daddydancool View Post
Man i hate you!!! now i need to do this since it's really a nice clean way to fix the batt, you just used foam that you glued there on the aluminium tray that you made? did you just used a normal alu sheet to do it?
Thanks a lot for you help!
The foam is just some adhesive-backed craft foam from the craft section at Wal-Mart. Comes in a 8.5 x 11 x ~1/16". Just cut, peel, and stick. Cheap too.
The metal is ~1.5mm thick 6061-T6 from onlinemetals.com cut and bent into shape.
