azjc
07.05.2008, 10:27 AM
Originally Posted by coolrunnings View Post
I Think the wanderer/feigao 9xl motors are longer and have more power right? believe the shorter medusa is the equivalent of like an L. I know that a feigao 9xl does work perfect on 4s but you will want mikes heat sink motor clamp no matter which one you get.
you right on the legth difference the XL can is 74mm and the Medusa is 60mm, but the deisgn the Medusa is better, also you could wait when Medusa releases the 70mm can which has been said to be August
