83gt
07.05.2008, 09:01 PM
Wow. I thought I'd perk up more interest with this one, being as there aren't many converted hellfires around here. Here's some more info....
The 9xl took a dump, so I ordered a 13t RCM pinion to run with my finned 8xl. I also switched out the BK 9920 for my quark 125b. Running with a 4s 8000mAh TrueRC. This should pack quite a punch, as long as the 8xl holds up. 13/52 @ 14.8v on the 8xl should give some nice speed.
If you noticed the wooden blocks under the revo battery tray I'm using.. that's temporary. I will replace the wood with some delrin or plastic blocks. The revo tray works pretty good for this application, so it will stay there I think.
I also want to replace the rims with the stock style black dishes. Although, the wide track is proving to be pretty fun. I can't make it traction roll for anything, even at 40mph +. It flies awesome. Very stable in the air, and easy to control. It's a lot more precise than driving the revo or savage, for sure.
I guess that's about it for now. I'm pretty much in love with it. :D.
J.
