GriffinRU
07.06.2008, 09:08 AM
Originally Posted by Serum View Post
How far can the R1 pro controller be pushed? does it handle 5S?
Far..., as long as software can handle it. Although I do not feel comfortable running close to FET's rated voltage.
What is the Tekin R1 Pro's amperage rating?
SPECS: Controls: Forward/Brake/Reverse
ON Resistance: 0.00005 Ohms (brushed fwd mode)
0.00015 Ohms (brushless mode)
0.00015 Ohms (brushed fwd/rev mode)
Input Voltage: 4 - 9 Cells, 2 - 3S Lipo
BEC 6.0 V / 3.0 A
Motor Limit: Brushed and Brushless, no limit
Throttle Profiles: 1-7
Max Current: Brushed Forward, 312amps / 624amps
Brushless per Phase: 104amps / 208amps
I will assume that stock ratings based on 26A per Fet @ 1sq-in pad with 1oz copper.
Modifications inside, extend current handling and power ratings, but do not overestimate pcb traces current capacity.
