George16
Supermaxx
George16's Avatar
07.07.2008, 08:04 AM
Originally Posted by Duster_360 View Post
The 2.5 has 4 small 2mm screws holding the diff cup to the ring - another weak point, don't know if 3.3 upgraded this or not. Neither are shimmed stock, so some are diffs work/last longer than others. The stock spyders are another weak point and a good nitro diff will eventually have a spyder failure.
They're the same on the 3.3.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
