07.07.2008, 10:48 AM
you will need to make an adapter that puts the negative pack, middle, and positive pack wire into a tap. Then you will still need your main pack wires going into the charger.
I say you don't need to worry about balancing with only two cells. Just measure them periodically with a voltmeter to be sure they are within .2v of each other.
