07.07.2008, 09:15 PM
I'm no expert as I understand it is narrower but if you consider that it also has lower CG due to the reduced tire diameter. it will handle differently from a Truggy or MT.
A good sway bar would help improve handling....
OT:
Anyone knows if I can fit the 12mm Hex hub and Wheel/tire of Slash to an E-Revo? I plan to put those tires and some 1/8th scale on-road car body to make a sort of E-Slayer....
