jhautz
jhautz's Avatar
07.07.2008, 09:32 PM
I'm sending mine all back when they have the new versions.
I just had my first MMM shut down on me. It had a good 8-10 hours of use on it. The BEC failed. It ran normal all day thru the 3 qualifiers and I shut it down and unplugged the battery as normal. About a half hour later I went to go change the battery and start prepping it for the main and it wouldn't turn on. Nothing. Just dead. If i started the fan spinning it would keep it spinning for a while as if it had a very low voltage running on it still and when I plugged a Rx pack into the receiver it actually started up and spun the motor on the bench for about 5 seconds then it quit again. I yanked the MMM and replaced it with another MMM I had all set up and sitting in the pit box just in case. (as it turns out a good decision) I am sending the dead one back and having it replaced and then when I get that back I am going to yank the other one working or not and have it replaced. I just don't trust that it will keep working. I thought I had a good one. And by comparison to what happened to others I did, but it just couldn't go the distance and I don't trust the other one to do it either.
On the brighter side... I won the B-main and bumped up and then took 3rd in the A-main for 1/8 buggy and took 1st in MT with the G2R Revo. Very good day for me. It made me forget about the dead MMM.
to make it...
or break it...
Silent...But Deadly
