Originally Posted by kevin23
I have been running my e-revo for a couple weeks now,still brushed though,and it is great,I went up a step in spring rate front and rear,added the sway bars.Totally different truck,I ran in the truggy class this week and lapped everbody in the 10 min main.I can't wait for the brushless,I am waiting for the mmm like everyone else.
I will be running the axi outrunner you have in your emaxx,the 8 turn.I have the cc bec,the novak cap,and the fan.
I will run this setup on 2 2s 5000mah 20c packs,what kind of runtime would you expect from this setup racing on a track?Wondering if I need higher mah to run the longer mains?
I run the same Packs and get 25 to 30 minutes of hard runtime.
You should be fine.
