10.04.2005, 03:12 AM
Mike, when you say dremel the old pinion off, do you mean to notch the set screw so that I might be able to get to it with a flat head screw driver? Also, when I put your pinion on, I can't push it in far enough to get it to line up with the spur gear, the set screw starts to go behind the motor plate. It's only about 2mm from being lined up perfectly so not that big of a deal.
Serum-
Sorry, no pics of the truck. It's been sitting for a while. The truck is being stored at my parents house and the engine is at my brothers house slowly but surely being put together.
It's just a stock looking grey Toyota truck with about 350hp. The only things that gives it away that it may be fast is the monster tachometer sitting behind the steeringwheel and maybe the big tires in back (255/40-17s) that's a pretty big tire for a small truck. Oh yah, carbon fiber hood also.
I'll get some pics of it for you if I ever get it finished.
