07.09.2008, 12:48 AM
Originally Posted by OldSoldier View Post
OK...I've been trying to come up with a good setup for my new E-Revo also. I'm currently using the following:
Quark 125, Medusa MR-036-060-1600V2-5 1600RPM/V, 15 tooth pinion, stock spur gear, I've tried 4s, 5s, and 6s. I'm still worried about heat, but performance is great at 5s and 6s. But I'm also having cogging issues that I'm having trouble fixing. Motor locks up some times while I'm coasting or braking. I'm still playing with speed controller settings to try to fix.
Check your radio setting, and make sure that you zero out the throttle channel adjustments before you program it. I run a 1500kv 60mm v2 in my hyper8 on 6s thru a 125b and it works fine. I do need to turn down the brake force though...
