02.27.2005, 02:27 PM
So what kind of amperage should you expect from a brushless setup? I have an E-Maxx and would probably get a Warrior 9918 with a Feigao 9L.
Also, in another article about the HV-Maxx Brushless system, the author said he mounted the Duratrax Powerpoles on it and didn't have any problems. I understand that the Novak systems are considered quite a bit milder than what people on this forum typically run, but is it really that big of a difference?
I did look to see what the performance characteristics were for AWG 12 gauge wire, and it said that max amps for chassis wiring is 41A and for power transmission is 9.3A. Based on this, I think it would be safe to say that going with the 45A PP connector would be safe.
What do you think?
