Originally Posted by TDC57
That 2 speed setup looks trick, when / what speeds does it kick in at, or is that your 3rd channel (?)..
Looking forward to see it run..
Good luck (not that you need it)..
It is an auto shifter, has a one way braing on the first gear, and a rpm based clutch on the second speed. Std traxass 2 speed in design, just outside of the case!
Thanks, I need all the luck I can get!!!
