Finnster
KillaHurtz
Finnster's Avatar
07.09.2008, 11:57 AM
I don't think that the kb45 motor would be terrible, but I think its just not the right motor for the app. 2300kv is too high for a 5S setup, esp w/ a cheap motor. I'd be looking at ~1600-1700kv. I can't imagine that thing wouldn't have to be babied to not overheat.
Also, usually larger diameter motors spool up slower, but have more TQ. That would be a great motor in an MT where you want tons of TQ for climbing and bashing, for a truggy I would want something with a faster spool up so its more responsive. Also, its a PITA if the thing has too much TQ as you don't want to either be: a) popping wheelies on the track b) diffing out badly in the F or c.) have to put really hvy oil in the CD to stop diffing out badly and F'up the turning capability
My 1st revo was a wheelie monster. It was a lot of fun for a while, but got to be a pain. I had to let off the throttle just to turn as the wheels barely ever touched the ground and it was hard to accel fast as it would just pop the F end up. It was like driving a big block '72 Impala when the hyper St is more of a porsche.
Not only that, it sucks having to stop and let the motor cool whenit gets hot, or worry about not being able to drive however you want for fear of overheating. "Long grass? Uh oh... I better go easy so I don't fry my motor..." My last revo was a 1515/2Y (1100kv) on 8S. Really good power but never got warm. I could drive and do anything I wanted and temps never budged. Perhaps I've just gotten spoiled, but its just liberating to be able to drive w/o worry. Hill climbs used to torture and fry lesser motors.
So I guess it all depends on what you plan to do with it. If its just for bashing about and doing spd runs then its not going to matter too much. If you plan on more racing I would go with a better suited motor, or at least a lower kv, higher V setup. 5S isn't too bad tho. Like arct1k, I don't see the point of dropping all this money on a nice trugg, $200 ESC, nice batts, then low ball the powerplant. Its a tempting thing to do, and I've certainly done it before, but it seems like you end up having to spend quite alot in the end to make it work right (clamps, heatsinks, fans etc) or just end up buying a good motor in the end. Even the Medusa 60mm motors sound like a great deal, Neu-like performance at only ~$100. And made in USA. The 60mm 2000kv motor geared high should be pretty snappy, quick and reliable, or even the 1600kv on 6S should be good. Else go cheap, be easy, and wait for the 70mm medusas to come out or the CC neus for a reasonbly priced option.
Wow.. that was a long post...and all just my humble opinion. :)
