Thread: Reciever Pack
crazyjr
crazyjr's Avatar
10.05.2005, 08:21 AM
Hey Squee. I assume when you say stock charger, you mean the charger that came with your Revo. If so, i gave up on using that charger because it would cut out anytime and eventually quit. what i currently use is a piranna digital peak charger from duratrax. If you got another charger that is adjustable, so long as it will charge at 1 amp or under, I suggest you try that. My settings are as follows. mah for 1100 set at 1200, for 1400 set at 1500. amps set at .9 amps. Peak detect set at 12mV/C. My packs have never let me down since i quit using the traxxas charger. don't forget you need a plug to match your pack. if you have a charger with spring loaded terminals you might be able to cut off the plug off your traxxas chargerand use it.
