Originally Posted by rcsammy
wow those motors are cheap
are they the same as the feigao 9L? they seem a but too cheap if you get what i mean
rootar why would gearing up make the motor run cooler?
edit: also what the difference between the different motors? like the 7,8,9 L, XL...
the differance in number eg 7 8 9L is kv the L motor 60 mm long the xl is 70 mm long the xL you can gear it up more and they tend to have lower kv which will produce less heat and they are cheap motor but if you do the right thing by them they will go great
