07.10.2008, 11:42 AM
Are you using an UBEC - It only has a linear bec so 4s will generate a fair amount of BEC heat.
Is the case "hot" all over - Do you need to do the internal mod? It could be worth looking at the RCM heatsink or just using an aftermarket one.
I managed to thermal mine on a buggy on a v hot day - I've geared down a bit and added a couple of 40mm fans...
30k in the middle is a good start
