07.11.2008, 01:58 AM
NONONNONONONONo!!!! It softens the compound of the rubber.. that would be bad for the cogs..
using wd is an onld drag racing trick, throw some on the tires and go do your burn out, tires come out clean and sticky
Thanks, I will just throw them on as is. Does traxxas have any spec on how tight the belts should be? They must need to be setup with some sort of deflection when pushed...
