Thread: Maxamps Lipo
MetalMan
MetalMan's Avatar
10.05.2005, 05:54 PM
Making Lipo packs isn't too bad, as long as there is a nickel strip soldered to the positive aluminum terminal (if there isn't, then you need aluminum solder, which is tricky to work with). The tabs can also be tricky to get put together properly.
Them being made in China doesn't make them worse, it just makes them less expensive.
