Darion
07.11.2008, 12:42 PM
bl-is-future,
Quick question about trans. set-up. I read that you have your trans locked into second so you can use the motor as a breaking system, I would like to do this too, more simple less stuff. I know how to lock the trans in gear but could I also use reverse while locking in second gear if the one-way bearing is replaced? I have a reverse module installed now but would like to ditch it if I could.
Thanks for the advice,
Darion
