Topspeedtimmy
trick mad power (tmp)
Topspeedtimmy's Avatar
07.11.2008, 01:10 PM
I emailed Traxxas with my predicament and they want me to send $45 along with the ESC and motor. I said, "no way, Jose", then I popped open the case and soldered it back on. Make sure you take out the rubber water seal around the plugs and the fet board should unplug from the brains. It seems to be solid. The dual Velineon runs kinda hot geared only 19/68 in 90 degree weather, it was about 170 for the motors and 160 for the escs after 15 minutes of running and taking some video.
The timmy - Revo 3.3 MM 9XL 4s , Rustler MM 4600 3s
The ferty - Dual velineon Revo 3s, Rustler velineon 3s
