Thread
Hellfire conversion
2
83gt
07.15.2008, 08:15 PM
Here's how she sits now. At least you get the idea of the basic layout. Quite a big change from what was there in the earlier pics. I think the balance will be better, and certainly some strengthening of the chassis is added. The battery tray is attached with M5 screws which are tapped into the chassis. You may notice the battery will sit much lower now, and there's some more weight up front. The motor mount is the lightning mount from RCM. The chassis holes did not line up, so I got the matching bulkhead from tower, and mounted the pair to an aluminum plate which I then bolted to the chassis.
I also put some 300k oil in the center. Perhaps that will help with my pizza cutters up front :D. I'm gonna give it another shot with the 8xl and BK and just be easy on it. I'm trying my best to hold out until I can grab up a castle built NEU.
08:18 PM
83gt
