83gt
07.15.2008, 09:26 PM
Originally Posted by A4DTM View Post
I hope you're using velcro under the battery as well so it doesn't slide forward and back. but looks really clean.
I guess none of the pics show the bracing front and back for the battery. There's a standoff bolted to the chassis that rests against the front of the pack, and a chassis brace in the back that rests against the back of the pack. There's no movement or wiggle room at all. I do plan on some sticky backed felt to protect the bottom of the pack from the chassis and mount, but it's not going anywhere ;).
Well, when I got it, the diffs were pretty bad. I just got some new "pulled from new Hellfire" diffs from eBay, but never checked them...
They're not so bad. I noticed though that the crown gear was shimmed in such a way as to push it further away from the pinion, and no shims on the pinion gear itself. Strange, since there was too much play already with the shims removed. I moved the shims to the opposite side, and put one on the pinion gear as well. Both diffs are smoother and more solid now. I think they'll do for quite a while.
I'm so happy with the build all together. This thing handles insane. I can't wait to get another run with the components moved around like they are. I REALLY can't wait to run it with a higher quality motor, lol. In the end, I think I would like to do 5s on a MM and Neu combo.
J.
