Originally Posted by ogrfre01
I have a Losi 8ight with:
-Esc: CC Mamba max
-Motor: Medusa 36-60-2000 v2
-Battery: Polyquest 4S 5000mah
-Gearing: 14/48
-CC BEC
-RCM battery tray and motormount
As the Medusa seems quite simular to the Neu, im woundering about the settings for the timing, should it be "0"? I now have it on default (10) and Punch control at (70) start power is default (Low)..... if i change the timing to 0, should i change something else? like punch control? start power?
I run my setups with timing at 0, increasing the timing increases performance with a brushless motor very little, but increases heat alot....its not a good trade off, punch control at 0 and in the Castle SW, I adjust the throttle curve instead of using the punch control
