asheck
07.16.2008, 07:48 AM
try running it for a full pack instead of just 5 mins and instead of the street try taking it to a footaball/baseball field in short grass and report back.....
I just geared like that to see how fast it would go with my highest gearing.Normally I run 24/68 and pull 46 mph,but can run that gearing as much as I want.I have a weak esc ,Quark 80b,that tends to start thermaling after awhile of running hard.I have added caps and done some heat modding,but it's just not quite enough.So I really can't push the motor to it's limits with that esc.
Where did you go wrong? Tire size? Ballooning Amount
Yeah since the ballooning amount is radius,I normally just add a 1/2 inch.
