Pdelcast
Pdelcast's Avatar
07.16.2008, 02:15 PM
Originally Posted by q8-maxx View Post
I do that for my futaba 2.4 and my stock radio and the problem still here.
Is it Possible the reason of my problem is my batteries?
Yes, it is possible. IF your batteries can't produce enough current for the motor, the ESC is forced to slow the throttle ramp rate, to keep the voltage from dropping too much (don't want a BEC dropout to cause a loss of control!)
What you will see is a sluggish throttle -- you pull full throttle, and the ESC will not go to full throttle until the battery voltage recovers, and this can be a noticeable delay if your batteries are not strong enough to drive the motor.
Patrick
Patrick del Castillo
President, Principle Engineer
