rchippie
rchippie's Avatar
07.16.2008, 08:32 PM
Originally Posted by blueb8llz View Post
thats a great calculator...thanks for that link!
but if i mixed them two into the diff at same time, i was thinking maybe the the thicker oil will stay on top and wouldnt mix on its own, so thats why i wanted to know if i should mix it by myself in a bottle....so im wrong...just double checkin.
The way i do it is as follows . Take a empty oil bottle & mix them in there then pour it into your diff cup . Put the heavier oil in to the empty bottlr first . then put the thinner oil in. Then turn the bottle side to side to mix. I would'nt sake it because you will put a lot of air bubbles in the mix. But if you do shake it all you have to do is wait till the bubbled rise to the surface & escape.
REAL MEN RUN BRUSHLESS
