blueb8llz
07.17.2008, 02:44 PM
greaaat. so this prolly means ill be chipping teeth constantly untill i do the shimming. which i have no experience of.
hey when you guys have the diffs fully assembled, when you spin the pinion (holding the shaft) does it spin smoothly? mine will spin kinda smooth but every once in a while, it would get stuck, and then itll spin again. does this mean that its not meshing good. im thinking the ring gear needs to be pushed up.
which is why the edge of the teeth were chipped , becuaes it was barely meshing. and now its stuck every so often when i spin cus its getting caught between the edge of the pinion tooth.
