07.18.2008, 12:29 PM
Just solder the cap across the power lines as close to the esc as you can - normally the easiest option it strip off some of the insulation .75" from ESC and solder there. Shorten the novak cap leads as they are a bit long. Touch of heatshrink and you are done...
