What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
07.18.2008, 07:44 PM
I would say skip ramming the truck, and go for his leg...
1515 1y on 6s must be a beast. are you still running the 2 speed? I use the solid center gear, 20/51 gearing, and 4s on the 2300kv KB45 motor. Still runs cool, and the mm is doing fine too. It can get a pair of trakpowers warmer than I like though... I have 4 trakpowers, maybe I should do 2s2p???
If I hit his leg there would be a lawsuit...if I hit his truck I get to watch him cry anyways!
Nah, I have a center spool and the 51T plastic gear, and actually my kit came with the spool. The Neu will get hot if I run until the batteries dump, but everything else is fine. Believe me when I say it has WAYYY TOO MUCH POWER!
I need Mike to make me a 30T pinion (23T there now) so I can put some load on the motor...all the donuts are making me fat.
