sikeston34m
sikeston34m's Avatar
07.18.2008, 09:42 PM
Originally Posted by kevin23 View Post
1.17 firmware
50% brake and reverse
0% punch control and drag brake
high start power and high timing(15)
1.5sec arming time 12v cutoff
that is how it is currently setup
22/40 gearing
You did go to the Castlelink software and click on the Software tab, and then choose "Update Firmware"? This sends the updated firmware to the controller. Just making sure with this step. It's very important.
You might try some punch control, but the most important thing you can do at this point in the setup, is broaden your neutral band for the controller.
Throttle Dead Band - change to Large
What is the little Red box I'm seeing in your setup?
