hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
07.19.2008, 02:36 PM
I have the TrueRc 15c 2 cell 8000's also. They are a tight fit, but still....they fit. Great for long runtime on 4 cell set-up.
I found these recently;
I was thinking 2 of these run in a series for a 6 cell set-up.
http://www.hobbycity.com/hobbycity/s...idProduct=7240
From the website;
The solid C rating and long life put the ZIPPY-Rs performance and value for money combination in a category of its own.
Spec.
Minimum Capacity: 4800mAh
Configuration: 3S1P / 11.1v / 3Cell
Constant Discharge: 25C (Minimum)
Peak Discharge (10sec): 35C
Pack Weight: 395g
Pack Size: 170x25x45mm
Charge Plug: JST-XH
__________________________________________________ _____
at 170mm long it may be a tight fit running the wires, but it should work.
4800X25/1000=120 Amps Constant --- 4800X35/1000=168 Amps Burst
enough for even the most demanding motors (neu)
not bad for under $60 a pop.
As for the e-revo itself... I did some measuring;
you can't see it good, but the measurement on the right is 10mm. So you have a total of 180mm in length, but the first and last 10mm only have 20mm of height.
Those batteries SHOULD work, but it will be close...
tell me what you think
~jarrad
