George16
Supermaxx
George16's Avatar
07.19.2008, 08:40 PM
Originally Posted by KINGSKID View Post
most of us won't be able to get the monster max to the point of thermalling. I run a 1.5d on 4s in a buggy and when the original fan failed the esc only got too 175 degrees. That was on a track in race type conditions in low 80's heat and a fifteen minute run. If your running a tamer motor or a slipper in a truck or truggy you may not need a fan at all.
Like you said,
. What about the rest that can thermal the ESC? There is always the possibility and a newbie might take faiulre of the fan as an indication that the ESC is still cool even though it's not.
I don't have any problems (knock on wood) yet on my V1 on 1515 1Y on 6S. However, I will be exchanging it for the V2 once the backlog is over.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
