07.20.2008, 01:57 AM
Ok, I will try to scare all of the parts up tomorrow and see what I can do. Not sure if the revo tranny case will have enough room inside, but that is what I will start with...
Also, do you think the 2nd gear clutch will disengage fast enough? I know there is a fair amount of rotation (180deg) that the second gear can rotate and the clutch pawl not touch the steel pegs. Just did not want it locking the clutch pawl out under hard braking...
