GorillaMaxx360
GorillaMaxx360's Avatar
07.20.2008, 09:00 PM
does anyone know the specific amp rating that is necessary in order to use the charger to its full capabilities (2 6s 8000mah for example). i would probably never use the charger to do such a thing :) because i don't even have one pack that big but for future reference i want to know what i might need and where i can get a good but not overpriced supply. Also is there anyway to figure out how much amps the charger is pulling from the power supply based on what you are charging that way i could do the math and see ahead of time if the power supply would be sufficient before charging 2 packs. thanks again for the info.
