azjc
07.20.2008, 09:46 PM
Originally Posted by GorillaMaxx360 View Post
does anyone know the specific amp rating that is necessary in order to use the charger to its full capabilities (2 6s 8000mah for example). i would probably never use the charger to do such a thing :) because i don't even have one pack that big but for future reference i want to know what i might need and where i can get a good but not overpriced supply. Also is there anyway to figure out how much amps the charger is pulling from the power supply based on what you are charging that way i could do the math and see ahead of time if the power supply would be sufficient before charging 2 packs. thanks again for the info.
to charge my 6s 5000 packs it takes about 130 watts and my PS puts out 14v which comes out to just over 9 amps
and the PS I use is this one for just under $100, make sure the PS is ov the cc/cv variety
http://www3.towerhobbies.com/cgi-bin...&I=LXKLP2&P=ML
