07.21.2008, 05:33 PM
Eek - This could mean bad news but generally means you just plugged it into the wrong adapater - Note the 2-4 hyperion taps are all the same size but you must put it in the correct slot...
Otherwise you need to check the voltage on each cell with a voltmeter
