07.23.2008, 12:01 AM
Yea, it takes twice as long, but it works.
Adding the fan to the case did wonders for me while charging outside in the Texas heat.
Sounds like a plan, I will try to keep it well ventilated.
Romano, do you think a 5s2p a123 packs will perform better with 100amp loads than a pair of trakpower 4900mah 25c 2s lipos in series? What kind of v drop can I expect? Setup is a gtp on road with a kb45 8l geared for about 45-48mph...
Thanks!
