TruckBasher
TruckBasher's Avatar
07.23.2008, 06:40 AM
Ok the rain stopped and I was able to do a 20-25min run.
- motor Kv 2075
- Same gearing as my Feigao 9XL 62/22
- MM with 5S2P A123
- everything else stock on E-Revo
- Run on slippery wet grass and stiff hill
This motor got power and torque, it can do wheelies but not as aggressive as the 9XL but it could be due to the slippery condition of the grass. Speed can easily go to 40-45MPH, not sure as I don't have a setup to check it but its faster than 9XL. Hill climbs were fun as this motor was not giving up, although the grass is a bit slippery but motor manages to pull it up.
Motor temp was hot 180-190Deg but then again I was doing mostly WOT on Hill climbs for 20min at least (One climb after the other) not to mention that this tires keeps on slipping due to low traction on the wet grass. ESC is still at 130-150, nosram fans are doing great of keeping the temp at bay. battery as always is just warm.
Damage: Rear wheel got ripped off the rim....i say thats power to the motor...
I am not that convinced yet to give it a 2 thumbs up due to the temps. But i'd say if you want a cheap alternative for bashing this motor will give you fun. Compare to external build and package this motor looks better than feigao. Specially the shaft its harder I cant flatten it with normal pile, unlike feigao a few scrapping and their off. I cant tell about the internal though.
I might be getting a 16xxKv motor range soon and try that.
I need a few more runs
E-Slayer direct drive to diff
